What is the recommended procedure to remove and replace the front brake rotors (they are behind the hub not over the hub)
Thank You
Oct 16, 2008 at 7:21 AM
KHLOW2008
✓Experienced Mechanic
Hi joe_jr2,
Remove brake caliper assy with mount
Remove CV shaft main nut.
Disconnect lower arm ball joint.
Pull out CV shaft from hub.
Remove 4 pcs bolt from nehind knuckle.
Tap out the bearing assy with hub and rotor.
Remove rotor holding bolt and rotor can be removed from hub.
