1990 Honda Accord Radiator fan
185,684 MILES • 4 CYL • FWD • AUTOMATIC
MOUA
Radiator fan and the condenser fan don't work!
I test both motor, its good, i changed the fan sensor and relay fuls it still don't work
Nov 4, 2009 at 6:48 AM
KHLOW2008
  • 41,812 POSTS
Hi moua,
At thermostat housing there is a fan switch. ?Use a jumper scross the connector and turn ignition switch ON, fan should come on.
Did you test the fan relay power supply?
Nov 8, 2009 at 5:08 AM
