1990 Honda Accord Radiator Fan
JACKH0L3
  • 5 POSTS
Engine Cooling problem
1990 Honda Accord 4 cyl Front Wheel Drive Automatic
a friend of mine has a radiator fan that runs even while the car is off.
any ideas as to what might be the problem?
Jul 12, 2008 at 2:19 PM
BLACKOP555
  • 10,386 POSTS
should run a little bit after it is off but not all the time, most likely cause is a sticking relay or a faulty coolant temperature SWITCH not sending unit, ground the switch out, fan still run the relay is sticking.
Jul 12, 2008 at 2:55 PM
BLACKOP555
  • 10,386 POSTS
if fan sdoes turn off, rpelace the switch.
