1990 Honda Accord idles down
214,000 MILES • 4 CYL • FWD • MANUAL
TIMEKO
When I turn the sterring wheel to the left or right, the engine idles down when it is in neutral and parked. Also, when highway driving, vibration from the front. There is no knocking or pulling in either direction.
Jan 12, 2008 at 9:37 AM
BLACKOP555
  • 10,386 POSTS
First the wheels should not be turned when sitting still, secondly the idle will go down when you turn the wheel as the pump uses up quite some pressure,
for the vibration check your tires balance.
Jan 12, 2008 at 11:22 AM
