1990 Honda Accord head lights and wipers
260,000 MILES • 4 CYL • FWD • AUTOMATIC
MCALLAN
on the head lights the high beams don't stay on when clicked on and the wipers don't shut off on the off possition I've changed both switchs in the steering colum
Nov 16, 2008 at 11:55 AM
KHLOW2008
  • 41,812 POSTS
Hi mcallan,
If the hi beams don't work at alll, you need to check the relay located in underdash fuse box.
The wiper if it works non stop in intermittent mode, the intermittent relay or intergrated control unit is faulty. If it works in normal mode, then the wiper motor circuit might be faulty and replacvement of wipre motor is necessary..
Nov 20, 2008 at 5:31 AM
