1990 Honda Accord fuel pump
ONESOBERDUDE
Engine Mechanical problem
1990 Honda Accord
where is the access point to remove and install a fuel pump intank
Apr 9, 2009 at 6:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
There is no access panel on the Accord. You will have to remove the fuel tank. Disconnect fuel lines and connector. Remove fuel pump mounting bolts. Then remove fuel pump from fuel tank. Installation is reverse of removal procedure.
Thanks for using 2CarPros.com!
Apr 9, 2009 at 6:30 AM
