There is no access panel on the Accord. You will have to remove the fuel tank. Disconnect fuel lines and connector. Remove fuel pump mounting bolts. Then remove fuel pump from fuel tank. Installation is reverse of removal procedure.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Thursday, April 9th, 2009 AT 1:30 PM
