1990 Honda Accord Front Wheel Drive Automatic
OK. I AM WRITING THIS MESSAGE SO ONE OF YOU FELLOWS CAN HELP ME. I HAVE 1990 ACCORD 180000 MILES. COUPLE OF DAYS AGO WHEN I WAS DRIVING BACK HOME FROM WORK I WAS LOW ON GAS SO PULL INTO A GAS STATION TO FILL UP. MY CAR WAS RUNNING FINE BUT NEXT MORNING WHEN I STARTED THE CAR HESITATED BUT IT DID STARTED BUT WHEN I PUSH THE GAS PADDLE THE RPM WENT DOWN AND THEN THE CAR DIED. I CRANK IT AND IT STARTED AGAIN BUT SAME THING HAPPEN. I THINK IT COULD BE FUEL FILTER OR IT CAN ALSO BE IGNITION COIL OR DISTRIBUTOR ROTOR. IT IS WORTH MENTIONING HERE THAT TWO WEEKS AGO I CHANGE THE TIMING BELT ON MY CAR AND THE IDLE WAS ERRATIC. I WOULD APPRECIATE IF YOU CAN ADVICE ME HOW TO FIX THIS PROBLEM
Wednesday, January 13th, 2010 AT 5:06 AM
