1990 Honda Accord engine idles up an down
ROSE2010
Engine Performance problem
1990 Honda Accord Front Wheel Drive Automatic 120000 miles
my car is getting the spark plugs black and the engine idle is not steady it goes up and down and the car is trowing black smoke.and if i clean the spark plugs they will turn black again,no oil on plugs just carbon black,like coated with heavy smoke.my idea is that it might be the idle control valve,but i could be wrong,anyone here no the right answer?
Jun 2, 2009 at 2:00 PM
KHLOW2008
  • 41,812 POSTS
Hi rose2010,
When idling surges, it usually is due to excessive air getting past the throttle body and it could be due to :
1. IAC ( EACV)
2. Vacumn leakages, PCV, dislodged vacumn hoses, faulty brake booster etc.
3. Idle speed adjusted too high.
4. Clogged coolant hoses to IAC and Fast Idle Valve or insufficient coolant.
Plugs running black could be due to injectors, throttle position sensors, fuel pressure or ignition timing.
Testing would have to be carried out to verify the source.
Jun 5, 2009 at 8:46 PM
