1990 Honda Accord clutch replacement
CJVARGAS
Transmission problem
1990 Honda Accord 4 cyl Front Wheel Drive Manual
How much does it cost to replace a clutch on a 1990 Honda accord
Jan 30, 2009 at 2:28 PM
  • 31,937 POSTS
Hi there,
Checking on Mitchell 1 the labour time is approx 6 hrs, a clutch plate, pressure plate & bearing will be around $300.00 allow some for the flywheel to be machined, replacement of the trans oil and some work shop consumables. check your local workshops for their labour rate.
mark (mhpautos)
Jan 30, 2009 at 11:35 PM
