1990 Honda Accord Clicking... CV joint, or Sway/Swing Bar..
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JJBREADMAKER
When I drive the car, there is a steady, rhythmic clicking - kinda hard to hear, but as speed increases, it clicks faster... also, if I turn RIGHT into a steep driveway or down a hill, it clicks REALLY loud... the sound is from the front end... I thought it might be a CV, but a mechanic said something like Sway Bar or Swing Bar or something... he said it was deteriorated and almost gone - to fix would be $500 or more... What do you think the problem might be?
Jan 6, 2009 at 1:46 AM
KHLOW2008
  • 41,812 POSTS
Hi jjbreadmaker,
Thank you for the donation.
If the noise is a constant clicking and increases in tandem with the road wheels, it most probably is the CV joints. However CV joints seldom clicks when they are moving in a straight line, unless the joint is in very bad condidtion and when accelerating, the noise level increases.
The sway bars would not have consistent clicking noise.
I would suggest getting a second opinion if you are not sure and where noise problems are concerned, we are not of much help.
Jan 6, 2009 at 3:55 AM
