In this vehicle the rotors are setup little differently than a typical front wheel drive car.
In order to replace the rotors, you will have to remove the knuckle and the rotor, then remove the rotor from the knuckle. The bearing bolted to the rotor hub will need to be removed.
I have attached the replacement procedure below.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Images (Click to enlarge)
Oct 21, 2021 at 1:17 PM
