1990 Honda Accord alternator and voltage regulator vs speed
ARROWTYKE
  • 1990 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 286,500 MILES
We replaced the alternator, and have the red battery light intermittantly come on. The battery is fully charged - even when the light comes on. Now the speedometer also doesnt work. The code 17 for speed sensor comes on. Are the two issues related?
Monday, August 30th, 2010 AT 7:20 AM
KHLOW2008
  • 41,814 POSTS
Hi arrowtyke,
Both should not be related. Speedometer not working are usually due to a faulty Vehicle Speed Sensor located on top of transmission housing below the thermostat housing.
If the alternator is reman, get it replaced. The voltage regulator for the indicator light is not functioning correctly. Check the alternator wire connectors first.
Wednesday, September 1st, 2010 AT 1:34 PM
