1989 Honda Accord Replacing Power Steering Hose
19,000 MILES • 4 CYL • FWD • AUTOMATIC
MORRISK1969
On the main power steering hose one end is fastened with bolts and the other end appears to be pressed in with an O-ring seal. How can I remove the O-ring side and when installing the new hose do I just press the end back in and it will seal. Is this a job better left to a professional? Thanks.
Jun 9, 2009 at 2:45 AM
KHLOW2008
  • 41,812 POSTS
Hi morrisk1969,
The end of the power steering pressure hose attached to the steering valve body does not have any O ring. It is a tapered fitting that self seals when tightened.
The pump side is attached with 2 bolts and has an O ring that should be replaced when removed.
Job should not be too difficult but you need some hand bending and removal of some externalparts for easier access.
Jun 14, 2009 at 1:04 AM
