Hi morrisk1969,
The end of the power steering pressure hose attached to the steering valve body does not have any O ring. It is a tapered fitting that self seals when tightened.
The pump side is attached with 2 bolts and has an O ring that should be replaced when removed.
Job should not be too difficult but you need some hand bending and removal of some externalparts for easier access.
SPONSORED LINKS
Sunday, June 14th, 2009 AT 8:04 AM
