1989 Honda Accord loss of gears
249,000 MILES • 4 CYL • 2WD • MANUAL
CIVICRYDER
while driving home on the freeway, i had cruise control set at 65 and all of the sudden i found the car redlining..i removed it out of 5th and put it back into 5th only to find it redlining with no grab. i repeated the same thing with 4th gear and 3rd gear worked for a little while making a screaching/grinding noise.....i had to drive in 2nd gear the remainder 10 miles to home at 30mph toughing out the screeching and the smell of burnt rubber as i put a smoke screen behind me...any ideas?
Sep 29, 2009 at 8:41 PM
KHLOW2008
  • 41,812 POSTS
Hi civicryder,
From the description it seems the clutch has faileed causing the problem.
The engine is revving due to the clutch slipping.
Oct 5, 2009 at 5:20 AM
