1989 Honda Accord ignition switch
PIGER123
Electrical problem
1989 Honda Accord Two Wheel Drive Automatic
how do you change the ignition switch on a 1989 Honda Accord?
Jan 1, 2009 at 7:57 AM
KHLOW2008
  • 41,812 POSTS
Hi piger123,
IGNITION SWITCH REMOVAL & INSTALLATION
1. Remove steering column lower cover. Disconnect 7-pin harness connector to fuse box. Insert ignition key and turn to "0". Untape key switch wires.
2. Remove switch mounting screws. Remove ignition switch. To install, reverse removal procedure.
© 2008 Mitchell Repair Information Co., LLC.
Jan 4, 2009 at 2:44 AM
