Hi piger123,
IGNITION SWITCH REMOVAL & INSTALLATION
1. Remove steering column lower cover. Disconnect 7-pin harness connector to fuse box. Insert ignition key and turn to "0". Untape key switch wires.
2. Remove switch mounting screws. Remove ignition switch. To install, reverse removal procedure.
SPONSORED LINKS
Sunday, January 4th, 2009 AT 10:44 AM
