1989 Honda Accord idle
378,000 MILES • 4 CYL • FWD • AUTOMATIC
PFSJIM
my engine idles fine when cold, when warm it idles fast in gear, then oscillates when in park. I have had problems with the cooing systemi the past but it was ok until I took the car to Goodyear to have the oil changed, then it started.
May 13, 2008 at 2:38 PM
  • 75,988 POSTS
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor.
May 13, 2008 at 11:17 PM
