1989 Honda Accord Failed E-Check in OH
HONDARONNIE
Engine Performance problem
1989 Honda Accord 4 cyl Two Wheel Drive Automatic 144km miles
I just got a bunch of work done on my car, flex pipe replaced and timing belt and water pump. i go to get my E-check and i fail the Emissions ASM: NO (nitrogen/Oxygen reading was 1620.6, PPM units, the Ohio Limit is 1313.0 units). does this mean that i need a new catalytic converter? i know the basic idea of what a CC does, but i dont know if it can be repaired or if i need a new one. i dont want to skimp on a quality job that will last for my car, because it has many more miles on it, but i don't want to break the bank. i need some advice soon, and appreciate any help.
Apr 3, 2009 at 11:59 AM
F4I_GUY
  • 3,302 POSTS
NOx is high combustion temperature.
On that vehicle you will want to check your EGR system to make sure it is functioning properly, or you may have a lot of carbon in your combustion chamber that is causing NOx as well. A de-carbonization may be in order to solve this issue. There are other possibilities as well, but this are the most common on your vehicle.
Apr 4, 2009 at 8:39 AM
HONDARONNIE
So with all these things, does getting a new Catalytic converter solve this problem? i figured it would, and that that is the CC's job. my very loving aunt is willing to pay for such an operation on my ride, but i don't want money wasted. is decarbing the engine going to solve this, really? the person i talked to said that these carborated engines on the honda accords are hard to pass on e-checks. will a new cc solve this? i would like to think of myself as environmentally friendly so i don't have a problem getting a new CC, aside from the cost, but that sucks.
Thank you, for your help... is 340 a fine cost... i hear that carborated hondas cant take a universal catalytic converter... is that true?
Apr 5, 2009 at 12:06 PM
