1989 Honda Accord electrical problem
260,000 MILES • 4 CYL • FWD • AUTOMATIC
CARGAR2
  • 11 POSTS
when i came home yesterday my brake lights were stuck on so i checked the brake light switch and noticed the plunger had had broke out of the pedal so i put in a bolt instead. then my cruise quit working so i replaced the brake light switch, cruise working now. however when i hit my brakes the interior lights dim and if i have my cruise on and turn on my head lights the cruise shuts off. i did notice a yellow and black connector not plugged in im sure the black is a diagnostic plug not sure were the yellow goes if anywhere. but it seems i have a short somewhere but i don't know how or where to look first. can u give me some ideas?
Jul 15, 2010 at 11:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
The dimming of the interior lights when using the brake pedal could indicate a weak charging system (i.e. battery, alternator). More likely though, it seems as though you may have a loose ground wire at the brake light switch. Inspect the wiring very well at the brake light switch and also have the battery and alternator tested, also inspect battery cables.
Jul 15, 2010 at 2:24 PM
CARGAR2
  • 11 POSTS
would this also cause the cruise to quit working when i turn the headlights on?
Jul 15, 2010 at 11:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, because the cruise control system will not operate if the brake lights are not operating.
Jul 16, 2010 at 10:30 AM
CARGAR2
  • 11 POSTS
do u have a wiring diagram i can use to chase the ground
Jul 16, 2010 at 1:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, i emailed the diagram to you so it will be a bit easier to read.
Jul 16, 2010 at 4:25 PM
CARGAR2
  • 11 POSTS
It's people like you that make this a great website. I tell people about it all the time. I appreciate everything you have done to help me get my problem solved. thanks alot
gary
Jul 17, 2010 at 1:33 AM
CARGAR2
  • 11 POSTS
i checked my e-mail carmengary@hotmail.com and i didn't see where u e-mailed me can u try again thanks gary
Jul 17, 2010 at 1:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sorry, i sent it to your registered email account which was "garyhammaker@yahoo.com" , do you find it there?
Jul 18, 2010 at 4:03 AM
CARGAR2
  • 11 POSTS
i did and now my car is fixed thank you
Jul 23, 2010 at 5:41 AM
