1989 Honda Accord DRIVER SIDE WINDOW
GERRINE
1989 Honda Accord Manual
HELLO, MY WINDOW ON DRIVERS SIDE CAME OFF THE TRACK HOW DO I PUT IT BACK ON? IT SEEMS THE WINDOW IS STUCK ON THE SIDE RUBBER AND THE TRACK GOES UP AND DOWN WITHOUT THE WINDOW HOW DO I PUT IT TOGETHER?
Oct 31, 2009 at 6:09 PM
KHLOW2008
  • 41,812 POSTS
Hi Gerrine,
You would have to remove the door panel, check if the door glass brackets for securing the window regulator is intact.
After removing door panel, you would be able to take the door glass out if it has detached itself from the regulator.
Nov 2, 2009 at 5:56 AM
