i have a 89 honda accord, it started having problems with a slow crank. then he charge light came on. i had the battery tested, it had a bad cell. i replaced with a new battery but the charge light stayed on. a few days later, the the original problem of slow cranking came back. i tested the charge system and it was not supplying enough voltage to the battery. i removed the alternator and had it tested. napa and 2 autozones said it was good. so i reinstalled but the problem continues. the charging system will not charge the battery. what else could it be??
Feb 16, 2010 at 2:43 PM
