1989 Honda Accord Battery Problem
BOWEN2417
Other Category problem
1989 Honda Accord Engine Size unknown Wheel Drive Type unknown Manual 180000 miles
I've been forced to replace my battery 4 times in the last few months because they keep dying and my car won't start. My mechanic says he can't find anything wrong with the new battery, the wiring , or the alternator. What could my problem be?
-pam
Jan 3, 2008 at 3:04 AM
MERLIN2021
  • 17,250 POSTS
Get an analog voltmeter remove the negative battery cable, attach the Black lead to the battery post, Red lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were!
Jan 3, 2008 at 3:06 AM
