driver side front turn indicator bulb
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
CASEGOD
How do I replace the driver side front turn indicator?
Mar 3, 2009 at 5:01 AM
  • 31,937 POSTS
Hi there,
You will need to remove the lens, it will be attached with two screws, gently hold the globe and push in & turn anti clockwise and the globe should come out, use a rag to hold the globe as often old globes are very brittle and may break in your hand, if this happens just use a pair of pliers to grasp & turn the globe, make sue that the correct globe is re fitted.
Mark (mhpautos)
May 17, 2021 at 5:38 AM
