1989 Honda Accord
LBROOKS2007
1989 Honda Accord Four Wheel Drive
How much do it cost to get a tune up, plugs and wires? I also have a skip in it and it might be a valve and it also ticks and leaks oil.....How much will it cost to get all this done???
Oct 31, 2008 at 7:35 AM
BRUCE HUNT
  • 3,754 POSTS
Youmight want to shop around for the list of items you have to be done. The tuneup will vary as will the cost of the work needed for the miss or skip and the oil leak.
Materials for a simple tuneup are going to cost in the area of $100 to $150. I would try air filter, gas filter, plugs, wires, rotor, cap. You might be surprised to find oil in the plug hole or holes and that will cost more to replace the valve cover and grommets.
Tuneip might take care of the skip and the oil leak will depend on where it is leaking from. Seals, oil pan, etc.
Nov 1, 2008 at 6:53 AM
