1988 Honda Accord Wont start
CJWISE
Engine Mechanical problem
1988 Honda Accord 4 cyl Two Wheel Drive Manual
When the car is driven for awhile and we shut it off it wil not start again.
Apr 24, 2010 at 8:03 AM
  • 75,988 POSTS
Next time it wouldn't start do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 24, 2010 at 3:34 PM
