When engine is first started (cold) the engine idle is way high. If you drive at all, soon it will return to normal or close idle. If you place in neutral immediately after first starting and running for very short time, it starts to surge idle (slow to fast idle surges) and will continue until you just drive the car a few minutes and engine fully heats up. Based on your answers to similar problems, should I be looking at IAC, PCV valve or neither of these?
Thanks,
J.S.
Thanks,
J.S.
Jan 26, 2009 at 3:32 AM
