1988 Honda Accord Idle Problems
12,100 MILES • 4 CYL • FWD • AUTOMATIC
TMATTHEWS1
Fuel Injected Lxi model. High RPM that pulsates between 1000 and 2000 RPM while at idle and at slow speeds when driving. Mechanic check vacuum hoses, EGR valve and cleaned mpv valve. All check OK but still have problem.
Dec 11, 2007 at 7:28 AM
BLACKOP555
  • 10,386 POSTS
have your mechanic clean out the throttle body and change the fuel filter, also see if you can have your IAC cleaned.
Dec 11, 2007 at 9:20 AM
