1988 Honda Accord Idle problems.
LORENNBL
  • 1988 HONDA ACCORD
Engine Performance problem
1988 Honda Accord 4 cyl Front Wheel Drive Automatic
I am working on a 1988 honda accord. Replaced fuel pump/strainer, checked for vacuum leaks. It had timing belt replaced a few months ago, but the idle surges. Really high idle upon cranking then fluctuates after warming up. Occasionally stalls completely after engaging transmissionb into gear. Any HELP?
Friday, August 6th, 2010 AT 12:18 PM
KHLOW2008
  • 41,814 POSTS
Hi lorennbl,
Is this a carburetted or fuel injected model?
Did problem occur after replacement of timing belt?
Sunday, August 8th, 2010 AT 9:12 AM
LORENNBL
  • 13 POSTS
It is carbureted.
Friday, August 20th, 2010 AT 1:17 PM
LORENNBL
  • 13 POSTS
And I am not sure if it was already occuring. Friend bought the vehicle 6 months ago from the original owner.
Friday, August 20th, 2010 AT 1:18 PM
KHLOW2008
  • 41,814 POSTS
If the timing belt had been installed, it would cause the symptoms described. Get the timing belt markings checked first.
Friday, August 20th, 2010 AT 1:31 PM
LORENNBL
  • 13 POSTS
Sooo. It is entirely possible the timing is still off?
Tuesday, August 24th, 2010 AT 12:10 PM
KHLOW2008
  • 41,814 POSTS
It is possible for the timing to be off and when we have a possible cause, it should be checked/tested.
Tuesday, August 24th, 2010 AT 12:25 PM
