1988 Honda Accord 4 cyl Front Wheel Drive Manual
I have installed a new fuel pump, when I put the sending unit back into the tank there is a leak. The leak is coming from the bottom of the sealing bolt and washer. I beleive this is the return fuel line but I'm not sure. I bought a brand new sealing bolt and washers but the problem still exsists. What can I do, or how do I properly tighten the bolt? There is no banjo bolt, just a washer on top and on bottom and the sealing bolt its self, what should the torque be for tighting this bolt?
SPONSORED LINKS
Tuesday, October 5th, 2010 AT 7:52 PM
