1988 Honda Accord From front tires: Sound like metal chain
EVOLUENT
Noises problem
1988 Honda Accord Automatic 150000 miles
The sound occurs during normal driving, at random. It seems to be triggered by turns, speed bumps, and braking.
It sounds like a dog chain being dragged on the floor - A sort of high pitched ringing. Almost a scrappng sound, dry, but mostly a metallic ringing sound.
Please help. Any ideas?
Feb 28, 2008 at 6:18 PM
PEAR69
  • 1,482 POSTS
Are your tires worn to the steel belts? If not make sure that the brake calipers are tight. Check the brake rotors and pads for strange wear patterns.
If all checks out it probably is your C/V joint on the half shaft.
Make sure the lug nuts are tight!
Feb 28, 2008 at 6:39 PM
VALENTINA
It sound that u might have a bad upper control arm....if u do u will get this sound when u hit bumps or holes on the road, and sometimes when u turn.
Feb 28, 2008 at 11:45 PM
