Electrical problem
1988 Honda Accord Manual
I have a question about a voltage regulator...
I have an '88 Honda Accord 2.0L which the alternator
on it is running at 65 Amps, but I have an alternator
off of a '90 Toyota Supra 3.0L runs at 70 Amps...
(Or I should say the voltage regulators are 65/70 A)
Now I believe I need to change the voltage regulator because the first time I start it up in
the morning - no battery light, but then when
I go to start it up for the second time and
every time after that during the day - battery light
If I rev it up to 3,000 RPM's or more
the light flickers/goes out at 3,500.
Can I replace the 65 Amp with a 70 Amp?
Do you believe that is my problem?
Thanks!
Thanks!
Nov 1, 2008 at 10:44 AM
