1987 Honda Accord Engine won't run
150,000 MILES • 4 CYL • FWD • AUTOMATIC
MISTERED47
I have an 87 accord, it will crank, run for 2 seconds and then quit. I have replaced the fuel pump twice. I have ruled out it being the fuel pump. You can spray starter fluid in carb and it will not run any longer than 2 seconds. I think that something is killing the fire. Got any ideas? Could it be timing related?
Mar 28, 2008 at 3:36 PM
BLACKOP555
  • 10,386 POSTS
if you keep giving it starting fluid does the vehicle continue to run?
Mar 29, 2008 at 1:19 AM
MISTERED47
No it quits. Will not run.
Mar 30, 2008 at 3:01 PM
BLACKOP555
  • 10,386 POSTS
is it possible you can get a fuel pressure test done on it?
Mar 31, 2008 at 12:15 AM
