1987 Honda Accord Engine Sputter
SMOOTHMON88
  • 1987 HONDA ACCORD
  • 4 CYL
  • 175,000 MILES
Car starts okay, but when I accelerate engine will sputter & lose power. Please advise how I fix this problem.
Thank-you for your help
Friday, January 8th, 2010 AT 4:28 PM
Check and test the following below:
Oygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Note:If it doesn't apply, disregard.
Friday, January 8th, 2010 AT 4:50 PM
