1987 Honda Accord cooling fans
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
CWENGER
Can you tell me where the sensor is that turns the cooling fans on when the car warms up? The car will over heat because the fans won't come on. There are two fans so I don't think it is the fan motors.
Thank you
Aug 5, 2009 at 12:20 PM
KHLOW2008
  • 41,812 POSTS
Hi cwenger,
The fan switch ( thermosensor ) is attached to the lower part of the radiator. It is blocked from view by the fan shrouds and if you go under the vehicle, it would be easier to see.
Aug 12, 2009 at 6:41 AM
