1991 Honda Accord Cooling Fans Not Working
WTVRITKS
I have a '91 Accord EX with a 132 CID engine and 232,768 miles. Both my cooling fans have stopped working. I checked the fuse and it's good. Both fans spin freely by hand. Can you help me?
Sep 17, 2007 at 12:17 AM
WRENCH
  • 57 POSTS
Start with disconnecting both fans using jumper wire from fan to battery see if they work if not bad fan, next check fuses in the engine compartment also check the relay its in there too, I believe that each fan runs on separte circuit one for radiator and one for the condenser, but if that does not help than to check the radiator fan find the fan switch witch is located on the right side of the cylinder head, disconnect wires and with engine cold should have no continuity (the resistance between the terminals) and as the engine warms up someware around 180 or 190 degrees should show continuity, if not then fan switch is bad. (dont run the engine too long and get too hot) if you can find the other fan switch than same test to see if its bad.
Sep 18, 2007 at 8:15 AM
Suggested Repair
Jump each fan directly to the battery to confirm the motors work. If they do, check the engine-compartment fuses and relays, then test the radiator fan switch on the right side of the cylinder head: no continuity when cold, continuity around 180-190 degrees. Test the other fan switch the same way if located. Do not let the engine overheat during testing.
Conversation Summary
A 1991 Honda Accord owner reports both cooling fans stopped working. The fuse is good and both fans spin freely by hand. The expert recommends jumping each fan to the battery, checking engine-bay fuses and relays, and testing the fan switches for continuity as the engine warms, without overheating it.
