1987 Honda Accord
LARDELLI
Engine Mechanical problem
1987 Honda Accord 4 cyl Two Wheel Drive Manual
Car used some oil 1/4qt every 3000 miles had oil pan replaced and now engine is using 1 qt. of oil in 80 miles.
May 18, 2008 at 12:40 PM
  • 31,937 POSTS
Hi there, you will have to determine if it is leaking or burning oil, if a leak you will have to wash motor down and identify where the leak is, if burning, that is a huge amount to burn , so you will need a mechanic to check the engine for serviceability.
Mark (mhpautos)
May 18, 2008 at 3:31 PM
