1987 Honda Accord
IMPORT RACER
Electrical problem
1987 Honda Accord 4 cyl Front Wheel Drive Manual
When i switch on high beams my wipers start going across the window.this only happens with the key on.I already changed the combination switch,but didn't make a difference.I also checked under dash for bad connections or corroded connections.I'm going crazy trying to figure this out.
Nov 10, 2008 at 9:43 AM
KHLOW2008
  • 41,812 POSTS
Hi import racer,
The only explanation that I can think of is the wiper wire is fused with headlight wires and is using the headlight as ground to operate.
Nov 16, 2008 at 4:27 AM
