Im trying to find the spout to add transmission fluid I cant locate it could you tell me where to look
Wednesday, April 22nd, 2009 AT 7:30 PM
KHLOW2008
MECHANIC
Hi valenciaslm,
Fluid is added via the dip stick for checking the fluid level which is screwed into the trans housing located at front of trans just below the battery. CMight be hidden from view by the lower radiator hose.
