1986 Honda Accord STARTING PROBLEM
CHIEF07
Other Category problem
1986 Honda Accord 4 cyl Wheel Drive Type unknown Automatic 178000 miles
The other day I was driving to work and my car just shut off. I have check the fuel pump and it is charging up. Fuel is going through the fuel filter. I check and clean the distributer cap and the clean the spark plugs. I don't know what it could be.
I can't get the car started. What could it be?
Feb 18, 2008 at 11:24 AM
  • 75,988 POSTS
You need to disconnect a sparkplug wire and ground it to the engine, have helper crank engine over-do you have spark? If so -try carb cleaner into the throttle body if it starts and dies -you have a fuel system problem -
When you turn key to On-do you hear the fuel pump come On?
Feb 18, 2008 at 7:22 PM
