1986 Honda Accord Re: What component is this
250,000 MILES • 4 CYL • FWD • AUTOMATIC
1ACCORDLOVER
  • 7 POSTS
This is to Docfixit, Certified 2CarPros Master Technician
You asked me to answer a few questions about my problem. Here are the answers.
PIC #1
Valve has 3 hoses
Pic of valve is circled in yellow
One hose is coming from the side (blue arrow) #20 side hose.
Second hose is coming from bottom (red arrow) #20 bottom hose.
There is a third hose attached to the side hose by a connector. The third hose comes from the bottom of the component right next to the valve (green arrow & green circle) #20 hose. There is nothing else connected to that component.
2 hoses #20 come from side and bottom of the control unit (if the control unit is the valve the answer is yes)
Is there one terminal? Yes, connection is coming from valve (circled in yellow), connection is (circled in Lt blue).
Colors of wires; solid black with red dots and red with blue.
Yes, the engine will run with it unplugged.
PIC #2
The side hose ( blue square) on the valve is hooked up to here near the carburator (blue arrow).
The bottom hose (red arrow) is hooked up to this pipe on the opposite side of where the arrow is.
[img:7d452b015c]http://www.2carpros.com/forum/automotive_pictures/420113_honda_1_3.jpg[/img:7d452b015c][img:7d452b015c]http://www.2carpros.com/forum/automotive_pictures/420113_honda_2_3.jpg[/img:7d452b015c]
Oct 21, 2009 at 12:15 PM
DOCFIXIT
  • 18,828 POSTS
Think I found it nothing was ever more of a pain than working on Hondas vacuum octopus. Item is crank Opener Solenoid Valve powered from ignition switch with swich off power is cut so check black/white wire from IGN key off if power IGN faulty.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_195.jpg
Oct 22, 2009 at 2:18 AM
1ACCORDLOVER
  • 7 POSTS
You said to check the black/white wire with ignition off. I checked the ignition switch with it in the off position like you said. The only wires that were hot are listed below. Solid black with white stripe was not hot. But I do have 2 wires that were hot. 1 is solid white and a solid white wire with a black stripe that was hot.
Is the solid white with black stripe the one you meant?
solid black with white stripe: not hot
Solid white: hot
Solid white with black stripe : hot
Oct 25, 2009 at 7:28 AM
