1986 Honda Accord oilpressure
TJ75
Engine Mechanical problem
1986 Honda Accord 4 cyl Front Wheel Drive Automatic
I had put an entire engine into my 1986 honda accord the engine came front a rear end wreck accord wit 66,oo0 miles on it. the oil light came on the car lost power and turned off. While it will turn but will not catch. Had oil in it enough just had it changed after replacement engine was put in
Sep 29, 2010 at 5:11 PM
  • 31,937 POSTS
Run a scan and check for any fault codes first, get it running and check the oil pressure with a mechanical gauge report the readings here, cold idle, hot idle hot 1500 RPM.
mark (mhpautos)
Sep 29, 2010 at 9:01 PM
