1986 Honda Accord LIGHTS THAT COMES ON
218,201 MILES • 4 CYL • 2WD • AUTOMATIC
SIDECAR
THE PRM-FI AND THE BRAKE LIGHT THEN THE MOTOR STARTS TO REV UP AND DOWN
Jun 11, 2008 at 6:11 AM
KHLOW2008
  • 41,812 POSTS
Hi sidecar,
PGM-FI check light indicates something is wrong with the engine management system.
At the ECU see if you can see a blinking light in a small window with the ignition switch turned on. Count the number of blinks and get back to us. The blinks will cycle over and over again.
Brake light indicator = blown brake bulb.
Park brake indicator = low brake fluid level.
Engine hunting maybe due to vacumn leakage and might be related to PGM-FI light.
Jun 12, 2008 at 12:49 AM
