1986 Honda Accord Injector Light and Thermometer
ACCORDHONDA
Engine Mechanical problem
1986 Honda Accord 6 cyl Four Wheel Drive Manual
The injector indicator on dash-board (PGM-FI) comes on after engine warms and stays on instead of going off. The temperature guage on dash-board rises very quickly. Also, engine doesn't start when overheated.
Feb 7, 2009 at 12:23 AM
KHLOW2008
  • 41,812 POSTS
Hi AccordHonda,
Locate the ECU under the driver seat and check the LED blinks to retrieve the Diagnostic Trouble Code.
Do you have coolant losses?
Does the fans works when A/C is turned ON?
Feb 16, 2009 at 2:03 AM
