1986 Honda Accord dogging out?
ROCKSTAR5887
1986 Honda Accord 4 cyl Front Wheel Drive Manual
hi my car is am 86' lxi accord and it starts but as soon i give it gas it dogs out and dies, ne ideas?
thanks
jason
Jun 4, 2008 at 2:53 AM
KHLOW2008
  • 41,812 POSTS
Hi Rockstar5887,
It could be plug cables, fuel pressure, TPS, MAP sensor and many other possibilities. More info needed.
Does the engine stall during idling?
Is the idling smooth?
Is starting easy after stalling?
Jun 4, 2008 at 3:02 AM
ROCKSTAR5887
yes it stalls while it is idleing and it idles smooth also, and it starts like 1-3 cranks after it stalls.
Jun 4, 2008 at 3:44 AM
KHLOW2008
  • 41,812 POSTS
Hi Rockstar5887,
Will the engine stall if you try to rev it up or the engine stalls only if you try to drive off?
lxi = fuel injected ?
Is there any PGM-FI warning light on?
Lets try with checking the MAP sensor first. See if the vacumn hose is detached or connected incorrectly.
Jun 4, 2008 at 4:48 AM
ROCKSTAR5887
when it revs it seems limited and then dogs out and dies if i dont let off the gas, yes it is fuel injected , my haynes manual dosent have or show a map sensor?
Jun 4, 2008 at 5:20 AM
KHLOW2008
  • 41,812 POSTS
Hi Rockstar5887,
So if you let off the gas, it doesn't die off immediately?
Looks like the fuel supply needs checking. Maybe a clogged filter.
A faulty TPS is also possible.
The MAP should be connected with a hose at the throttle body and mounted near the firewall.
Jun 4, 2008 at 5:38 AM
