1985 Honda Accord Radiator Problem
270,350 MILES • 6 CYL • 2WD • AUTOMATIC
TERRENCE.JONATHAN
Recently the fans on the radiator have stop working making it impossible to drive long distances. Was just wondering what the cause may be and what i should do to fix it.
Jan 29, 2010 at 1:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Will need to test a few things to find out what the cause is. Disconnect fan motor wire connecto and connect it with 14 gauge wire to a good 12 volt battery. if fan runs then motor is OK. this means thermal switch, radiator fan switch, coolant relay, timer relay, coolant temperature switch or A/C relay may be faulty. if fan motor does NOT run when connected directly to good battery then replace fan motor.
Jan 29, 2010 at 2:15 PM
