1985 Honda Accord I NEED HELP
SERG55408
Brakes problem
1985 Honda Accord 4 cyl Front Wheel Drive Automatic
How and what do I need to change my calipers and brake pads?
Jun 9, 2008 at 4:34 PM
KHLOW2008
  • 41,812 POSTS
Hi serg55408,
You need to remove the caliper mounts bolts (17 mm hex 2 pcs, 17 mm box or ring spanner required.) and brake hose (14 mm open end or hose spanner).
To replace brake pads you need to remove lower slider bolt (12 mm hex bolt, 12 mm ring spanner) turn caliper outwards and remove old pads.
Push piston back into caliper with G-clamp and old pads on piston.
Ready for installation now.
Jun 10, 2008 at 3:13 AM
