1985 Honda Accord carb
266,543 MILES • 6 CYL • 2WD • AUTOMATIC
CATCAT
k my car is having problems staying running. when you start it it starts and bogs to a stall, or when driving it will just cut out . all power is there its just the fuel . the fuel pump works fine is just on the drivers side throttle or what not seems to stick i think . what can i do to help iy get gas and stay running
Oct 22, 2008 at 11:26 PM
KHLOW2008
  • 41,812 POSTS
Hi catcat,
You need to check the carb idling circuit. Sometimes the fuel cut solenoid is faulty and will not be able to idle.
Oct 27, 2008 at 12:59 AM
CATCAT
[quote:a9934ffc2d="catcat"]Engine Mechanical problem
1985 Honda Accord 6 cyl Two Wheel Drive Automatic 266543 miles
k my car is having problems staying running. when you start it it starts and bogs to a stall, or when driving it will just cut out . all power is there its just the fuel . the fuel pump works fine is just on the drivers side throttle or what not seems to stick i think . what can i do to help iy get gas and stay running[/quote:a9934ffc2d]
Oct 27, 2008 at 1:17 PM
