1985 Honda Accord alternator
SKIPPED
Electrical problem
1985 Honda Accord 4 cyl Front Wheel Drive Automatic Alot miles
alternator removal
Jun 26, 2008 at 1:51 PM
KHLOW2008
  • 41,812 POSTS
Hi skipped,
To remove alternator.
1. Disconnect battery negative terminal.
2. Remove alternator mast wire 10mm hex nut and disconnector coupler.
3. Release alternator adjusting bolt and nut.
4. Pull at alternator belt to loosen it and allow slack for removal.
5. Remove lower alternator base bolt and nut.
Alternator ready to be taken out. If control solenoid box above is restricting, unloosen holding bolts and move it aside. If you need to remove it, mark all the hoses accordingly, wrong installation will cause engine running problem.
Aug 24, 2020 at 7:44 AM
